You are here: FME Server Administrator's Guide > Licensing > Configuring the Number of FME Engines to Start > Editing the Process Monitor Configuration
To add or remove an FME Engine by editing the Process Monitor configuration:
  1. Open the following file using a text editor:
    <FMEServerDir>\Server\processMonitorConfig.txt
  2. Near the end of the file, locate the blocks of text beginning with # Start FME Engine 1
  3. Locate the first line beginning with # CMDFMEEngine and uncomment it (remove #). For example:
    CMDFMEEngine_Engine3=...
    In the same block, uncomment the line beginning with # WAITFMEEngine. For example:
    WAITFMEEngine_Engine3=...
    Similarly, if you would like to remove an FME Engine, you can comment out these lines.
  4. Repeat for each additional engine you want to add (or remove).
  5. If more engines are desired than what is already provided, simply copy an existing block, paste it below, then update the values to make it specific to the a new engine.
  6. Save and close the file.
  7. Restart FME Server.
  8. You can confirm that the FME Engines are licensed and running using the Web User Interface and the instructions in Verify the Installation.
